I have started installing my skyjaker 9" lift on my 79 this weekend and have ran into a few problems... currently I am installing the radius arm drop brackets and reinstalling the radius arms and new 4 degree c bushings. I have taken of both coils and have removed the driver side radius arm. My questions are:
1. do I have to take both radius arms off at the same time in order for this to install easier?
2. do I have to disconect the front driveshaft in order to do this? ( because my problem is getting the radius arm to line up with the drop brackets... the radius arm needs to move forward about 3-4" in order for the radius arm bracket to line up with the radius arm drop bracket...)
3. will I have to disconnect the rear driveshaft when I get ready to install the rear add-a-leafs and 5" blocks???
Any help is much appreciated.
