9" drain plug
texan79&96
my 9" is tilted up for driveshaft angle and was wondering if anyone has ever tapped a hole for a drain pulg . would this be a good idea to weld a small length of pipe onto the housing and tap it for a drain plug and maybe a little gaurd for it?
Broncoholics
Broncoholics
Washington State
I drilled out the bottom of the 9" and tapped the housing for a allen type plug. Installs flush with the bottom of the pumpkin. Works pro.
Billz4x4z
Carnesville,GA
Thats all ya need to is find a allen head plug or the 3/8 internal square head plug,drill and tap the hole,no shield to worry about
davids78bronco
fabricator extraordinaire
central Oregon
only about 1/8" Look at the diffs on older toyotas, they have a drain and protective ring, that you asked about
79bigbronco
Calgary, Alberta, Canada
I would still put the little piece of pipe on, had an allen key type plug in my diff stuck out 1/8" , rock hit it lost my diff fluid, plugged it up with a bolt & ductape, filled it with 20w50 engine oil, as that was the best we could come up with at the time, got home but cooked my gears. First thing I did was the little pipe around the hole, you can never have too much protection! [-X
fred tyler
