'88 Bronco II Won't Start
BayouGhost
My B2 was starting fine a few days ago, went out to start it, and it will turn over, but won't fire. I added several gallons of gas, re-set the inertia switch, but still nothing. I'm thinking fuel pump, but not sure how to check it, also what else could I check? Thanks in advance for any help!
Gary J
andre
gatineau hill quebec
need to find out is it fuel or spark or timing gears
3 possibility
test for spark may be igniter in distibutor
gas pump may have two pump check for corosion sending unit. fuel pump relay. also starter relay as fusable link. fuse
check compression too
get you on rigth track if you folow these step
BayouGhost
I took the fuel line off right before the second fuel pump on the frame, hit the switch, and no gas came out. Gonna pull the tank and replace the fuel pump. Thanks for all the help!
Gary J
Gary wilder
