88 bronco 2
darben83
2.9L 4x4
I bought this truck wrecked for about 300 bucks. still started. I replaced body work from pull a part. fendor, headlights, grill.
installed a new radiator, flow over/washer fluid res, ac compressor hose and pulled out all of the body work myself. new tires and a new battery.
Now I got all of that done and got my tags and such and bumped it and it started right up with no issues. Driving down the road i had a really bad shimmy for about 15 minutes and it just stopped. For the first day on the road it ran fantastic.
So the second day I was driving down the road on a small 30 minute venture and was doing about 60 mph. I got hit with an incredible lack of power, rpm's just dropped, the truck still runs at this point but I have to put the peddle almost all the way down just to maintain speed up to 45.. but it will not accelerate. If I punch the peddle all the way down it will full throttle accelerate like nothing is wrong but if i let off just a little the rpm's drop again and i lose speed. If I let my foot off the gas and allow the rpm's to drop.. they will do so and they truck will cut off. it'll start right back up and be fine for a few more moments before it does it again..
Any clue at all as to what my issue might be?
andre
gatineau hill quebec
may be you're catylitic converter clog
try to see if you're exaus pipe if you got good flow
some time when truck are standing for long time of in collision cat may break and piece
inside may clogg cat or evend the muffler
there os2 sensor may be abel to remove to try it out
ad prom on mercury mistique cat broke and muffler 2/3 block no power some time just die but re start
D
darben83
Thanks for the tip and i will check that out this week.
Gary wilder
