After driving the truck, whenever I put it in park the idle shoots up about 500 rpm. If I goose the gas pedal it comes back down. None of the cables are hanging up, does anyone have any ideas.
First I would scan it and try to get a code you can also check you TPS and see if it is failing. My 89 did this after offroading it was the cable on mine though right at throttle body the plastic tube cracked and allowed the sleeve to hang up.
Thanx for the ideas, the cables aren't getting hung up checked that and also checked the idle air and was clean not goobered up. Would the map sensor have anything to do with it. It's one on the few sensors that hasn't been changed since I've had the truck. Also there are no codes.
