87 bronco
bradl
bought a 87 bronco cant get the harmonic balancer off to adjust the timing broke every puller tool what can i do?
bradl
i would like to have it running by monday
BLADE262US
Michigan
Why are you trying to take the balancer off to adjust the timing ? Theres no reason to do this unless your timing chain set has multiple keyways and if its the stock one I guarentee it dont . About getting it off sometimes when you take the big 15/16 center bolt out the flat washer behind it stays and your puller could be pushing against that washer which rest against the balancer so it will never pull it off . I usually pull the bolt and washer then put the bolt alone back in and push against that with the puller make sure the bolts your using are grade 8 or better and that there screwed in the same length dont try to pull at an angle because it will bind harder against the crank . Hope that helps :D /emoticons/[email protected] 2x" width="20" height="20" />
eholt80
