86 Ford Bronco II 2.9 4x4
Giddyup2
If i try and accelerate fast it hesitates and bogs right down, once i lift my foot off the gas and apply pressure slowly it is not quite as bad. I replaced the fuel filter and took it for a test drive and I thought i had fixed the problem as i could give it full throttle without hesitation. Then i parked it and the next time I drove it the problem had returned. Any ideas as to what it might be?
broncodane
Hello, Hello, I have to say its not cool when this happens, I went for a few weeks completely stumped as to what was causing this to happen to my truck I have the same truck as you, and it was acting the same way I was sad to see that you hadn't had a response It would have saved me a ton of money and inconvenience, so heres something that hopfully will help to narrow things down... have your fuel pressure regulator checked, that was my problem, simple but it'll do it. I hope that helps, I can tell you a few other possibilies but the regulator would be a good place to start.
bbr7515
mt sterling ky
my 86 2.9 4x4 did the same thing. it was the o2 sensor...before i changed it, it was like the motor wasnt getting any fuel.hi the gas and almost die..but since i changed o2 sensor its all been good..
bbr7515
mt sterling ky
my 86 2.9 4x4 did the same thing. it was the o2 sensor...before i changed it, it was like the motor wasnt getting any fuel.hit the gas and almost die..but since i changed o2 sensor its all been good..
kevindunn
same thing happens with my '88 2WD 5speed
my brother says my truck's an old man, and that i should drive it like an old man.
maybe i'm flooding the engine?
anyways, i've been driving it like an old man and i guess it's working.
im going to check the o2 censor and so on. . .
can you all list any other possibilities of what it might be?
viperfangs2
Northwest Florida
There is something about 86 i go to a lot of different sites for bronco 2s and ford rangers and the 86 year models are always in need of help!!
kyleh01
