79 bronco
kdjohnson21
I have a 79 bronco 351 that starts to bounce when taking a long curve at low speeds (35-45) the tire does have a can of fix a flat in it. after the can was put in the front tire started to bounce while going straight but nothing major and suggestions
Bronc76
The tire may need to be balanced. You could rotate the front and rear tires to see where the bounce occurs, then you'll know where to look.
Elmo
Forsyth Georgia
if it all dries in a puddle then you have about a 12 oz weight to offset --- cant be done
Broncoholics
Broncoholics
Washington State
Yeah, I used to add almost a pound of weights to my 38"SX to ballance them. If you have fix a flat in there, get it our or replace the tire. A tire could also be egg shaped.
pimpa shrimp
since its the tire with the fixe a flat crap in it just have it broke down ( tire off rim) and get the extra crap out of there then have it balaced and it sould balance up good
50joe
Trenton NJ
Every one I ever broke down with fix a flat in it, didn't really dry. Turned into a really messy slime. Usually when you break the bead, it looks like a dinasaur just sneezed on the tire machine.
fred tyler
