68 bronco
J
joe_dozer77
Iowa
no it dont run..... yet!!!!it has a 289 3spd the motor is not locked up and we have got it to turn over a couple times by jumping wires across but not by the ignition
Broncoholics
Broncoholics
Washington State
The best way to start the motor if its been sitting is pull the distributor and use a long screwdriver and drill so you can spill up some oil pressure before you start. Thats after the oil change and squirting oil down each cyl hole.
