4" lift
RICK3009
can anybody give me advice on the best 4" lift for a 92 bronco.
EB Bronco
It all depends on what you want to do with your Bronco. If you are just going for the look and not gonna wheel it much you can go with a lift with just blocks for the rear and radius arm drop brackets for the front. If you are going wheelin where you will be flexing the suspension a lot you'll probably want to go with Superlift, Rancho or some other lift that offers the extended radius arms. I'm not a fan of blocks because they ride rougher than the stock suspension and you take a chance of spitting on out on the trails. I have the Rough Country 4" lift, but I did a Sky Mfg shackle flip on the rear rather than the blocks and have been very happy. Rough Country is probably about the least expensive lift you'll find. Do a search on lift kits on here and you will find all kinds of information about the different types of lifts. :)>-
Roger
BLADE262US
Michigan
Id say go with superlift there brackets are very high quality and there pivot brackets have the holes for a 6 inch in them too if you ever decide you want to go bigger . :D /emoticons/[email protected] 2x" width="20" height="20" />
sreaminbronco
Dallas
Is a 4in. lift the highest you can go without worrying about worn ball joints and stuff on the front axle on a 92'?
