33X12.50 or 33X10.5
walkercreekbronco
I have a set of aluminum wheels I pulled off of my 91 F-150 that I'd like to use on my Bronco.
The aluminum wheels are 7.5 inches wide. BFG recommends (website) that 33X10.50's are as wide as I should go on these wheels. Is this too narrow? (3.5in Wild Horses lift, Bushwacker flares). Can I run 12.50 tires on these wheels without a problem?
31 x 12.5s require a minimum rim width of 8.5 inches but the 31 10.5s will fit on a 7" rim. If you go to this site http://www.tirerack.com/tires/index.jsp and enter the tire size you are considering, and click on the Specs column it will give you all the relavent iformation on a particular tire. If you mount 12.5s on a 7 inch rim you void the manufacturer warranty.
