3-4 inch lift
Micah_86
I AM LOOKING FOR A 3-4 INCH LIFT KIT UNDER $1,200. OR UNDER ANYTHING WILL DO!! PLEASE HELP. MY DAD IS IN IRAQ AND HE ISNT GOING TO HELP ME WITH THE $. PLEASE HELP. IS THERE ANYTHING ELSE I CAN DO TO MAKE THE SUSPENSION BIGGER OTHER THAN A LIFT KIT. THANKS.
Txquadhunter
N. Texas
17938[/snapback]
Broncograveyard.com and most all other lift companies has 3-4" lifts for under $1,200. just look each kit over to see what best suits you. 3" blocks instead of add-a-leafs will drop the prices. but add-a-leafs best way to go.
If you search you'll find you can take the front coils from a 2wd Big block F250 or F350 to gain 2-3" front and rear shackle flip on rear for the same.
Just be safe and don't skip much on the lift end. bad suspension can cause lots of trouble.
a 3" body lift is cheap and easy to do. if bigger tire what ya looking for. Me I trim fenders to gain tire clearance and keeps top heavyness down
tilted78f150
Broncograveyard.com and most all other lift companies has 3-4" lifts for under $1,200.  just look each kit over to see what best suits you.  3" blocks instead of add-a-leafs will drop the prices.  but add-a-leafs best way to go.If you search you'll find you can take the front coils from a 2wd Big block F250 or F350 to gain 2-3" front and rear shackle flip on rear for the same.
17963[/snapback]
if you havent done anything yet www.jackit.com is probably your best bet for front springs $127.99 for 4" skyjackers .... the shackle flip is the cheapest way for the rear (if you have the equip to do it yourself)build your own (i did ) if you dont have the $125 to buy them(BUT) there is one problem .... youre gonna need axle relocation plates because it pushes the rearend forward about 3/4" to 1" wether you build or buy them the plates are under $20 ... then you need longer shocks(ebay store scratch_and_dent) $15 ea., drop track bar bracket (i built myself, (shimmed front coil perches)(did myself ) instead of dropped radius arm brackets, but you will need the 4 or 7 degree bushings .... you can buy the whole poly kit for $124 with 4 or 7 degree bushings at (acmetruckparts.com) and drop pitman arm $50 on ebay....
so there is your 4" lift for under $600 any questions (ASK AWAY) i just finished mine !!!!!!!!!
GubNi
The hills of East TN
I have some 4" lift springs for $50. You can get 4" lift add-a-leaf springs cheap. You can also drop the front coil bucket 3" and add a 3" block. You will also need 4* C bushings for 4" lift and 7* for 7" lift. Drop pitman arm is nice, but not required with 4" lift.
jrod66
What year is your bronco? I have a 4 inch lift kit for a 79 bronco that is complete, with add a leafs and not blocks, make me an offer, I will sell it cheap, I am in nor cal so probably have to ship, what is your postal code?
Sandoval_broncosauria
