2 bbl carb question
JLasvegas
I decided to check my carb because i felt there was a possiblity the needle and seat were sticking, well after checking it and taking out the float, I decided to reinstall the float and put the carb top back on the original gasket
can the gasket be re used?
what happend was truck started after a few cranks "bowl was almost dry" then it ran for a few seconds and gas looked like it overflowed and now it doesnt want to start because its flooding
could it be the way the float was put back it, or possibly the needle or could the old gasket be causing gas to leak all over
any ideas? its hard around here to find a gasket kit for a 2bbl stock motorcraft carb
please help
BroncoJoe19
OK.. off to a good start :) /emoticons/[email protected] 2x" width="20" height="20" />
Sure, you may want to use a little permatex, or other gasket sealer (perhaps a silicone seal) just read the label and make sure it is ok for fuel.
What do you mean that it looked like it overflowed?
absolutely!
IF you are getting a flooding condition that you didn't have before, you probably bent the float height adjustment tab, and now the float is not putting enough pressue on the float valve into the float valve seat to stop the flow of fuel, thus causing flooding, OR you may not have reinstalled the float valve properly.
your kidding right? if you see gas leaking all over does it look like it is coming from where the gasket is?
please help
Yep... don't smoke around that carburetor.
JLasvegas
JLasvegas
problem solved, I took the float out and the needle and reset them and adjusted the float arm a touch, apparently I bent it up alittle when taking it out
I reinstalled the gasket since it wasnt torn and put the top back on and tightened it and she fired up nicely and seems to run good
