2.8 to v8
trjarvis
going to put a 302 in what bellhousing will work and will the 84 5 speed work with the 302 thanks for your help
Dallasbronco
Try posting this in the Bronco II forum, this one is for full-sizes. Go to www.advanceadapter.com, they have alot of info on making v8 swaps into Rengers/Bronco II's. I doubt the current 5-spd/tcase/axles are up to v8 torque, and I don't think the bellhousing will bolt up. Hope this helps.
BLADE262US
Michigan
Well from my experience the first thing thats goona blow chunks will be the 7.5 rear end its gotta go . My B2 had a 4 speed in it when I got it and someone had made a bellhousing adapter to go from the tranny to the V8 . The tranny is not rated for that kinda torque so it was a matter of time on that one . Best bet is advance adapters for motor mounts,A C4 tranny with advance adapter tranny kit so it will mate to the stock T case which is plenty strong, Use an eplorer rear end as they are the same as the F150 31 spine 8.8 just narrow . ( cant use a ranger 8.8 because the frame width is weird and wont fit in the bronco 2 because you cant move the spring pads far enough out ) And last but not least I used a fullsize bronco drive shaft in mine because I got sick of watching the stock B2 one bounce down the road, Oh and for headers the advance adapter ones are a waste of money the james duff ones are way better , That will take care of making it move and be plenty strong enough . I never broke my little dana 28 up front and it held up to a 351W but I think I was just lucky when I redo it this spring Im goona hang an eplorer dana 35 up front unless I can find a dana 44 had plans on narrowing a 79 full size axle I have to fit in it and hang it on leaf springs but the guy I got the springs from off ebay stiffed me took my money and never sent them . So not sure what Im goona do with that yet . Hope that helps and if you have any questions feel free to ask . :D /emoticons/[email protected] 2x" width="20" height="20" />
kyleh01
