1995 Bronco
HeyJude10
Hey guys,need some help.1995 Bronco,driving home the other day the ABS light came on,the O/D light started flashing,and the speedometer quite working all at once.Tranny went into limp home mode.Checked fuses first,and it keeps blowing the #5 fuse in the power dist. box.Also,replaced the rear speed sensor.Still having same problem.Any ideas or suggestions would be greatly appreciated.
BroncoJoe19
See what's on #5 fuse and start disconnecting the component(s), and see when the fuse stops blowing. The problem will be localized to that portion of the circuit.
I never had the need to build one of these, but it looks interesting.
http://www.inliners....tech/tech6.html
yo Hey!
Take a look @ this TSB; in thsi instance Ford describes Fuse as E; which is prob marked as #5 in your PDB Cover
TSB 95-5-21 Fuse "E" Inoperative - ABS Light On - Back-Up Lamps Inoperative - DRLs Inoperative - MIL On - Speedometer Inoperative
Publication Date: MARCH 13, 1995
LIGHT TRUCK: 1992-1995 BRONCO, F-150-350 SERIES
ISSUE: On some vehicles the HO2S wires in the 12A690 (subassembly of the 14B060 battery cable) harness may become chafed and the vehicle could exhibit any one of the following conditions:
ABS light on
Speedometer inoperative
Back-up lamps inoperative
Daytime running lamps inoperative
Trailer battery charge relay inoperative
MIL on, displaying Codes: 172, 173 or 41 for HO2S failure
Inadvertent PCM Self-Test
ACTION: Replace the damaged wire harness and HO2S sensor. Refer to the following procedure for service details.
SERVICE PROCEDURE:
1. Disconnect negative battery cable.
2. Disconnect the solenoid terminal and positive battery cable from the starter.
3. Pull the cable downward to inspect the 12A690 harness for chafing, pinholes, etc. If necessary, remove the convolute and tape from the 12A690 harness located next to the lower RH side engine mount.
4. If the 12A690 harness is damaged, replace the 14B060 assembly (F5TZ-14300-EA) and the HO2S sensor (F4UZ-9F472-A).
5. Inspect Fuse "E" and replace if necessary (D9ZZ-14526-D).
6. Clear all codes stored in memory.
7. Retest and verify the concern has been resolved.
PART NUMBER - PART NAME
D9ZZ-14526-D Fuse - 15 Amp
F5TZ-14300-EA Harness Assembly
F4UZ-9F472-A HO2S Sensor
OTHER APPLICABLE ARTICLES: NONE
WARRANTY STATUS: Eligible Under The Provisions Of Bumper To Bumper Warranty Coverage
OPERATION - DESCRIPTION - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - - TIME
950521A - - - - - Replace Harness Assembly, HO2S Sensor And Fuse "E" (If Overloaded) - 0.7 Hr.
by Ford via Steve83
You can try to test for Codes using our pal, BroncoJoe19's process; http://broncozone.com/topic/14269-code-reader/page__p__74587entry74587
run it around to heat the engine up and shift thru all gears incl Reverse.
then; turn off all accesories/lights, etc.
Do KOEO portion first
For Key On Engine Running (KOER) portion, the engine has to be @ normal operating temp.
Post any codes found here or look em up in my broncolinks.com site.
btw. I know this has happened to at least 2 others in past year.
13 12A690 Wire Assembly
If Image does not appear see it @ http://www.thedieselstop.com/faq/9497faq/maint/stj/images/k20713c.gif
H
HeyJude10
yo Hey!
ABS light on
SERVICE PROCEDURE:
by Ford via Steve83
H
HeyJude10
Man I found it!!! I took off the battery cables and found a very tiny split in the negative cable that you really have to wrench to see. It was corroded inside so I cleaned it,hooked it back up and wouldn't you know it worked.I drove straight to the autoparts store and got a new cable,came home and slapped it on.Works good as new!! I knew it had to be something grounding out somewhere and did spend some time looking for it, just not with a as well as I thought. Thanks so much!!!!
