esulkowski
- Joined
- Aug 26, 2005
- Messages
- 5
- Reaction score
- 0
what is the least expensive way to repair fenders ?, do bushwackers help ? any other ideas...thanks for your time
There's not much I can add to SeaBronc's reply. There just aren't too many ways around this one. Fenders are actually pretty easy because you can just go to the junkyard & unbolt one from any F-truck or Bronco & go home & put it on yours. A junkyard fender runs about $30. If you want to get *real* spiffy then bring it down to your favorite local body shop or Maaco & show them your truck & give them your paint code and have it sprayed the correct color. I've done this a couple times and it cost about $90 for them to do it for me. Alternately you can go to any PPG outlet with your paint code & they'll mix up any color you want & put it into a spray can for you (2 cans is generally plenty for a single fender, 3 cans will do both fenders)what is the least expensive way to repair fenders ?, do bushwackers help ? any other ideas...thanks for your time
I had the same problem with my bronco rotting in all the standard areas. For most of the spots I either harvested metal from my burnt up Jeep Cherokee or just used extra sheet metal we had laying around on the farm. I used rivets to stick the new metal on, then I used bondo to patch up the areas. I cut out a lot of old metal out to esure that no rust would be left behind. I tried to patch up the fenders with sheet metal at first, but I learned that sculpting the curves on the rear fenders is very difficult. If you go to http://broncograveyard.com/bronco/c-188 you can get just the arch of the rear fender for about $40 a peice. That's what I did for the fenders, but everthing else is just sheet metal I had laying around. Add that to about $15 per gallon of body putty then the primer and its really not that expensive, definatly a lot cheaper than going to a body shop. Here's some pictures of what I did. This was also my first major project so let me know what you think. It just takes a lot of time and patience to get it as close to perfect as you can.what is the least expensive way to repair fenders ?, do bushwackers help ? any other ideas...thanks for your time
What happened...??? Don't REAL men use duct tape anymore?what is the least expensive way to repair fenders ?,
Wow. That is probably the best answer on this topic so far! Just make sure you put primer on the duct tape so that the paint can stick better! Otherwise it will just flake off. Then use the money you saved to buy a case of Bud!! I like your thinking, Joe!!BroncoJoe19 said:What happened...??? Don't REAL men use duct tape anymore?
Duct tape, and a can of spray paint... man you can't get any cheaper than that!
It'll look like $hit, and last about a year, but it'll still look better than cancer, and will leave plenty of money for beer. Just make sure that you use good quality duct tape.
OK... where's my hammer?... just hit me in the head with it.
joe
The cheapest way is to cut out the rusted areas, which leaves you more room for the wheels. You'd be surprised what 2 inches all around the wheel opening will remove in terms of rusted metal. And it can be done to look near-stock, if you take your time and roll the outer edge over the inner panel. IF trimming the opening doesn't get all of the rusted area, then the patch panels or replacements are the best option. Fender flares will cover most of the area you've cut out, but are easily torn off when 4wheeling.what is the least expensive way to repair fenders ?, do bushwackers help ? any other ideas...thanks for your time
