1991 bronco no crank no start.
c myers
texas
I have a 91 bronco with the 5.0 efi with terrible electrical problems , so many that it must be something simple , I'm simple, but after chasing power, grounds, relays , still nothing. Please help.
Do accessories work like dome light? Headlights, Wipers radio?
C
c myers
texas
even did the obd 1 ce diagnostic which worked, but stagnant codes low exhaust temp, rich fuel all in a no run scenario
Sounds like it could be a bad fender mounted solenoid.
Battery cable goes to one stud. The other big stud goes to the starter.
The little stud comes from the ignition switch.
Probably start there. You can jumper across the two big terminals with a ***** driver or pliers or something to see it will turn over.
C
c myers
texas
not getting power to s terminal jumper to s terminal cranks it over, power to and thru the ignition switch, not making it to the solenoid.
Do you have a wiring diagram?
Didn't think the ECM had anything to do with cranking.
Neutral safety switch?
