1988 manual transmission...
craiganblank1
Kershaw, SC
I'm still considering what to do with this frame and body off of my 1988. I want to strip it down to the frame and start from scratch. It has the manual transmission. What transmission is this, and is it gonna need a lot of work or are they pretty hardy. It is a 4spd with overdrive I think. ANyone ever dealt with an old one of these. Also... If I decide to go with a 460 or big engine will this tranny work with it? Thanks.
madmax
quakertown pa
Probably the M5OD-R2, I'd be changing it out for a ZF5, the only real advantage of the M5OD is that you have 4 speeds PLUS overdrive, If you want to keep the 4 speed plus overdrive you might want to switch to the ZF ment for deisle engins but you'll need an adapter plate, you might then not have a long enough input shaft, it might be too short to reach the pilot bearing. You might be able to change the internals out into the case designed for gasoline engins but I don't know, Any ZF5 experts out there?
Below is something I found a long time ago
Model: SROD (single rail OD)
Manufacture: Tremec
Type: Four speed overdrive w/ push down reverse
Years: 1978-83/4
Truck:
Engines: 300, 302/351
Construction features: Aluminum, synchronized in forward gears, shifter near back
Trans code: B
Gear ratios:
- 3.25, 1.92, 1.00, 0.78, 3.25 (300/302)
- 3.01, 1.78, 1.00, 0.78, 3.01 (351)
Model: TOD (top shift overdrive)
Manufacture: Tremec
Years: 1984-85
Truck: F100/F150/F250
Engines:
Construction features: Aluminum case and shift tower
Trans code: B
Gear ratios: 3.29, 1.84, 1.00, 0.69
Model: Tremec 3.03
Manu factor: Tremec
Type: Three speed non overdrive
Years:
Truck: F100/150/250
Engines: 240 (RAN), 300/360/390 (RAT)
Construction features: Cast iron case, top-loader design, syncro'd first gear, column shift
Trans code: C
Gear ratios:
- 2.42, 1.61, 1.00, 2.33
- 2.99, 1.75, 1.00, 3.17
- 3.41, 1.86, 1.00
Model: NP-435
Manufacture: New Process
Type: Four speed non overdrive
Years: 1965-90
Truck: F100/F150/250/350
Engines: 300, 302/351, 351/400
Construction features: Non syncro first gear, cast iron w/aluminum top plate, shifter in top, PTO Pass side
Trans code: A
Gear ratios: 6.69, 3.34, 1.79 or 1.66, 1.00
Model: T18
Manufacture: Borg-Warner
Years: 1965-93
Truck: F100/F150/F250/F350
Engines: 300, 302/351, 460
Construction features: Non syncro first gear, case iron case, PTO port on passenger side
Trans code: F
Gear ratios: 6.32, 3.09, 1.69, 1.00
Model: T19
Years: 1983-91
Truck: F250/350
Engines: 460, 6.9/7.3
Construction features: Full syncro, case iron, PTO port on both sides
Trans code: P
Gear ratios:
- 6.32, 3.09, 1.69, 1 (83-86 F250s with 460 and 4wd)
- 4.02, 2.4, 1.4, 1
- 5.1, 3.0, 1.8, 1
Model: T85
Years: 1965-71
Truck:
Engines:
Construction features: Non-syncro first gear, case iron-side loaded case w/ 9 bolt cover
Trans code:
Gear ratios: 2.94, 1.94, 1.00
Model: T86G/H
Years: 1957-64
Truck:
Engines: 223, 292
Construction features: Non-syncro first, cast iron case, shifter on the side
Trans code:
Gear ratios:
- 2.80, 1.69, 1.00, 0.70, 3.80 (G-6 cylinder)
- 2.57, 1.55, 1.00, 0.70, 3.49 (H-8 cylinder)
Model: T87
Years: 1948-75
Truck: F250
Engines:
Construction features: Non-syncro first gear, case iron-top loaded case w/ 9 bolt cover
Trans code: E
Gear ratios:
Model: T89
Years: 1956-71
Truck:
Engines:
Construction features: Non-syncro first gear, cast iron-top loaded case with 9-bolt side cover
Trans code: D
Gear ratios: 3.17, 1.75, 1.00, 3.76
Model: T98
Years: 1948-64
Truck: F100/250
Engines:
Trans code: F
Gear ratios: 6.40, 3.09, 1.69, 1.00, 7.82
Model: M5OD-R2 (M5R2)
Manufacture: Mazda
Type: Five speed overdrive
Years: 1988-96
Truck: F150 and F250LD
Engines: 300, 302
Construction features: Aluminum throughout, fully synronized, integrated bell housing
Trans code: M
Gear ratio: 3.91, 2.24, 1.49, 1.00, 0.80
Model: ZF S542/S547
Manufacture: ZF
Years: 1987-94 (S542) and 95+ (S547)
Truck: F250/350
Engines: 300, 351, 460, 6.9/7.3
Construction features: Aluminum throughout, fully synronized, integrated bell housing, PTO covers on both sides of case
Trans code: Z (88/9), C (88-97 close ratio), W (89-01 wide ratio)
Gear ratios:
- 5.72, 2,94, 1.61, 1.00, 0.78 (gas engines)
- 4.14, 2.37, 1.42, 1.00, 0.78 (diesel engines)
C
craiganblank1
Kershaw, SC
WHen taking this bronco apart in order to rebuild it are they're any special things that I need to look for and hang on to? I know that there is a lot of rust on the underside of this thing. Thanks for the info. I know i'm going to keep all of the trim pieces, etc... from the interior.
Coastersfwb
