1985 bronco II restoration
ruddy
Hello everyone,
just started in the late 1985 bronco restoration and I have already found a couple of not working parts.
the fuel pump: found this two:
http://broncograveyard.com/bronco/i-80314-83-85-fuel-pump-171-2-8l.html
http://www.ebay.com/soc/itm/170974650590
and the carb misses out the choke thermostat (and the mounting ring) and cable that connect's it to somewhere.
I have found the thermostat itself:
http://www.rockauto.com/catalog/moreinfo.php?pk=40041&cc=1106132
http://www.ebay.com/soc/itm/160586249456
but the mounting ring and cable I don't know where to find it (maybe it has a specific name that I am not aware of).
Can you guys help?
picture bellow with missing parts highlighted.
thank you in advance. I will keep this post through the whole restoration process so it can help others in the future.
PS - did I get the parts right? sending it to Portugal it's not cheap :)
Rodolfo
Hey Ruddy,
The rind that holds the choke in is the: Choke retainer ring.  There should be a single wire that attaches on the post comming out of the front of the cover.  Look for it at LMC Trucks /www.lmctruck.com/ford
The wire that you show on the piccome from the TPS or THROTTLE POSITION SENSOR. there is a male plug to in the wiring harness to plug it into.
Good Luck
