1984 bronco ii
7111127
been running good for few years christmes eve i took it out drove it about 1/4 mile it died
found a bad ing coil and hole in gas line fixed them
still wouldnt start
so i replaced disturber cap rotor spark plugs wires etc i got good spark and gas still wont start
any ideas?
1984 bronco ii 2.8
andre
gatineau hill quebec
di you try to put gas in carb see if it start
if yes may have clog gas filter
if still no start gas and spark are there check compression
my have timing gear jump
di you try to put gas in carb see if it start if yes may have clog gas filter
done all that but compression test
and wut is timing gear jump
Elmo
Forsyth Georgia
So if you pour a bit of gas down the carb does it start ? Andre is suggesting that it may have jumped time,as in the timing chain being VERY worn and getting enough slack in it so that it slips on the teeth of the timing gears. Possible but not very likely. More probable that there is something else causing your problem.
andre
ON 2,8 ENGINE IT NOT A CHAIN IT GEARS DRIVE WHIT PLASTICK TEETH
just breack no warning
IT NOT A INTERFERENCE SO VALVE WILL NOT HIT
BUT STILL HAVE TO TAKE OFF PART OF FRONT OF ENGINE TO GET TO IT WATER PUMP TIMING COUVER EXT
BEST THING DO COMPRESSION TEST FIRST
if gear broke egine will turn faster then normaly do
Bronc76
If you're getting good spark, its probably safe to say that its not in the ignition. You might want to change the fuel filter next.
oh i forgot 2 post on here i posted on other forums 2 get ppls ideas
turned out 2 be blown head gaskit i replacing the motor with a 4.0
andre
if you're swamp to a 4.0 ltr engine
get donnor truck like explorere or better ranger
get engine ecm and all the wirering u need
not see a 4,0 ltr carb yet
and try to use a explorer radiator have dual core not like 2.8 sigle core
if you use original diff engine is lot's stonger thend 2.8
most of the guy's swamp for ranger 8.8 inch diff
other way to got is v8 302 cid
in both case prepare to spend some time building and swamping parts
need any info get to talk to guys in here that did the swap
good luck let us know how it going
fred tyler
