1978 ford bronco
ford8624
My broncos only problem I have is that red wire hanging on the bottom gets hot only when i turn igntion all the way over before i start it. I traced the wire it splits into another brown one that goes to solenoid and igniton control module. It runs good but the wire just stays hot almost to the point of melting but it doesnt theres no shorts anywhere else.
andre
gatineau hill quebec
there two wire there did you trace both of them
bad connection check it out
youre red /green line may b ok but red look like yellow may be short
but heat up near feed sorce
is it hot when it run ??
some control module and coil will get hot because not running keep power not sending it out
if running it ok
if needed more info
like engine size auto or not
try to get wirering diagram to pin point promb
may have diagram here
Dittliesquat
Resistor wire.
Red / green. I'd recommend getting a GOOD repair manual. It helps make sense of such things.
What year truck do you have? and what engine?
BUCKIN'94WFO
Dallas Texas
What kind of stereos, amps or OTHER types of things do you have running off of your "keyed" ignition source? Folks run in to the same problem when they pile on fog/running lights into the headlight switch causing IT to overheat as well! Basically- that's what fused relays are for. Just a thought, maybe you've already found AND fixed the problem.
fred tyler
