1969 stock am radio
RTBronco
After 5 years, I want to put my stock am radio back in the Bronco. Problem is I can't figure out the sequence of the spring washers, brass washers, and c-rings that install on the right ( dial selector) side. Any help would be greatly appreciated. Thanks RT
Bronc76
Can you post pics? The only sequence I had was the plate, retaining ****** and two knobs.
R
RTBronco
I'll try to post pics. On the right side, the **** you would use to turn the dial, there is a series of a gear, and 3 spring washers and 2 brass washers, and 2 c-rings. These are supposed to put tension on the gear, so it will turn the dial, but will spin freely if the dial is turned to its limits.
Sandoval_broncosauria
