Manual to Powersteering
Brett67
I have a 72 Bronco with a 302, manual 3spd column shift, and manual steering. I got a powersteering pump, a rock crawler gearbox, and the conversion bracket needed to mount the gearbox. With the gearbox and conversion bracket bolted to the frame, the conversion bracket has the gearbox mounted closer to the inner fender panel and the splined input shaft on the gearbox is 5 or 6 inches closer to the steering column. With very little length adjustment, my steering shaft is way too long, and the inner fender panel is in the way. What needs to be done to correct this problem?
Crude dude
Phoenix, AZ
You will have to install a slip joint in the steering column. Most people try to get by without doing this but there is too much bind on the u-joint that connects the steering shaft and the gearbox. If you do not have a way to add a slipjoint then you could install 2 u-joints but then again when you install the shaft it would have to be exactly the right length when you cut and install the joints onto it. As far as the fender wells go, I dont know. Maybe a sawzall would help?
What Crude said., plus;
It's always a "walk in the dark" trying to re-engineer a critical system like the steering.., with the intention of gett'n it done as cheap as poss. :eek: /emoticons/[email protected] 2x" width="20" height="20" /> (been.., done..!)
After all is said & done, you could have as much $$ outlay as if you bought the kit. :-B
Having said that.., with some precise measurements., & spline-count.., the suppliers (Tom's for one) can set you up with a "lower" shaft (W/U-joint & the lower half of an already attached "rag-joint).., and the upper half of the rag-joint....possibly already attached to an "upper" shaft.
The rag-joint allows for frame flex., & measurement imperfections. i.e. stops binding.
This would be a "bolt-in"., re-install steering wheel & "GO"..!
(this is very close to stock '76-'77 P/S set-up)
------ OR -------
They can supply the parts & you can cut/pin/weld your shaft if you have that capability.
----------- "SAFETY" being the "key" ingredient here....!! -----------
OH...! In some cases., there is a way to shorten that long stock shaft., drill & re-install the pin & re-use the "BELL" swivel joint on the box spline. Not pretty but works in a pinch..!
Brett67
This would be a "bolt-in., re-install steering wheel & "GO"..!
------ OR -------
Sandoval_broncosauria
