Intake manifold ?
cetmed
Northport FL
Hey i need some help I have a 1990 Bronco doing a complete rewire going to a carb
got an edlebrock manifold and carb from a friend, but I'm not sure what is what as far a all the holes in the manifold go, could some one post pics and explain what is what,like egr and all the fitings are for.
last time i saw a carb it was on an AMC so its been a while thanks for the help
sorry if this has been covered before did a search unable to find what I'm looking for
92broncomann
Coolidge, Arizona
Hey i need some help I have a 1990 Bronco doing a complete rewire going to a carb got an edlebrock manifold and carb from a friend, but I'm not sure what is what as far a all the holes in the manifold go, could some one post pics and explain what is what,like egr and all the fitings are for.
If this isnt an original engine someone did a sweet hack job on your truck LOL. Its not that big of a deal as long as your in a non emissions state, other wise thats a EFI truck. Why not post up some pics of what you got so far so we can see what your dealing with???
C
cetmed
Northport FL
I'm trying to post pics
I switched to a carb to get the bronco running I spent 2 years trying to fix the FI had it in multiple shops
I'm in Florida no inspections, Did a rewire with a painless weatherproof 20 circuit kit
Just not sure about vacume lines or EGR its not an EGR carb its an edelbrock 1406 needs rebulit
Does any one have a pic of what goes where?
No pictures, but I can tell you what they are.
Picture #1 side view of intake. 1. the hole to the left of the carb mount is the main vacuum port, (your vacuum tree goes here). 2. the hole at the bottom under the carb mount is for a Heat control valve, (the other half of a heat control valve mounted on the driver side exhaust manifold, together they give the engine better start and run characteristics and require a Ported Vacuum switch).
Picture #2 the plugged hole next to the distributor is for the temperature sending unit.
Picture #3 the open hole is another main vacuum port and can either be plugged or have a vacuum tree to shorten the vacuum hose run for something that needs main vac and is mounted in front of the engine, (all depends on what you plan on doing with vacuum stuff).
Basically it is the same as a stock, intake manifold used on a 302 and similarly for 351W ** but with better flow characteristics. It allows re-hooking all the original vacuum stuff up.
I can go into more detail on vacuum stuff, but since it looks like you may have a truck that was converted from an EFI to Carb you may or may not want to bother with it. I have a diagram of what I recommend for vacuum devices. Mainly they are for better start and run characteristics, it does not include the emissions control. Since it is a converted engine, that won't matter as it is officially, in most states, an Off Road Only truck.
C
cetmed
Northport FL
Tanks for the info
I'm the one who converted to carb needed to rewire the entire bronco
It had severe electrical problems I later discovered what they were when I took out all the old wiring out
Just needed to get it running got laid off as a truck driver need transportation asap
