jackedupbronco420
- Joined
- Jan 7, 2009
- Messages
- 5
- Reaction score
- 0
I have a 96 Ford Bronco with an 8 inch suspension lift. I want to get 44 Swampers. Will I need a body lift too?
You will need at least 12 inches of lift and some wheelwell cutting.
Yeah, I read that anything bigger than 36's you have to run at least a Dana 60 and the minimum. Get a hold of 1 ton gear and your set!I wish you luck, the 8.8 and the D44 can't hold up to that abuse. 37's is pushing your luck, 44's is insanity. I would love to hear an update how its all holding together for you.
What exactly do you do with the truck for 44" tires? I know a guy that runs 44" on his 84 silverado. He had to swap out from the 350 to a 454 to have enough power and ran with all 1 ton running gear. Plus he has a total of 21" of custom lift. he also had to have custom drive shafts and huge rotors. Monster of a truck and one **** of a beast, but he cant go rock crawling or play in the mud that often because he always comes across problems.
please keep us updated on how well those stock diffs hold up to the 44's lol
