Spark plugs and wires
Redneck86
First On Race Day
Colorado
I would go down to Checker Auto and get some ACCEL 8mm Super Stock wires and some Champion plugs. If you want they also carry MSD wires, but there more expencive.
BLADE262US
Michigan
I always run the bosch platinum plus 4,s and MSD spiral core wires , Also running MSD box never had a problem with spark :D /emoticons/[email protected] 2x" width="20" height="20" />
Shadow_D
Schenectady, NY
I've used the Bosch Platinum plus 4,s in my Beast but she didn't like them for some reason :( /emoticons/[email protected] 2x" width="20" height="20" /> so I went with a set of standard STOCK plugs.
bko4x4er
with my 302 i run bosch platinums, 8mm wires ( recommend 9mm) , accel brand wires and distributer cap and rotor.
and also accel ignition coil but thats just me. they work fine. nothing performance or anything.
love_my_bronco
Spokane
with my 302 i run bosch platinums, 8mm wires ( recommend 9mm) , accel brand wires and distributer cap and rotor. and also accel ignition coil but thats just me. they work fine. nothing performance or anything.
just a quick question what exactly does a MSD ignition do? ive been thinking about it but i dont know what it is.
bko4x4er
im not for sure , correct me if im wrong but i think instead of sparking once at a time, there are multiple sparks per a normal spark. thus more performance. like for every normal spark theres like 2 or 3 from an msd igniton. im not posative.
BLADE262US
Michigan
MSD stands for multiple spark discharge and what it does is lets say your timing is set @ 12 BTDC at lower RPM I think it was 3000 rpm ( may be wrong on that ) what it does is @ 12 BTDC the first spark will occur just like your ignition does now but it will continue to spark until 20 deg after TDC ( top dead center ) and at the higher RPM,s it is a continuos spark for that duration , so the chance of a missfire is nill and the fuel is more completely burnt . You can put them on anything that has a spark plug and a way to trigger the box . :D /emoticons/[email protected] 2x" width="20" height="20" />
