88BroncoBlack
i heard an exhaust leak today, looked underneath, what is the tube comin off my exhaust behind the cat, it was off
Exactly. The air pump sends additional air down to the cat to provide additional air to it will burn hotter. It's just like the old fireplace bellows. More air, more fuel, hotter temps, lower emissions. The airtube should be on the converter housing. It may be behind the converter itself but it IS on the housing. The only tube that should be coming off the exhaust runs to the airpump. The best way to go will be to repair it but if you can't right now you can always crimp-off the nub on the converter but try to do it right at the end so there's enough clean tubing left for a repair later on.its an air tube. the air from your smog pump goes through the valve and to the cat. it pumps fresh air to the cat which i believe helps heat the cat up because it works better at higher temps.
