ciruspilot
- Joined
- Mar 23, 2008
- Messages
- 21
- Reaction score
- 0
Hey anyone know why my speedo cable will spin in reverse but not in forward????
Depending upon the year of your truck, you may or may not have a spedo cable.Hey anyone know why my speedo cable will spin in reverse but not in forward????
I agree with Hopps. Your problem is mechanical, and has nothing to do with the sensor. IMO.If your cable is broken in such a way that it hooks the other side of the cable in reverse and slips when it is in drive that will be that cause of why it only spins in one direction.... I had one do that to me on my 85 chevy..... Take it off and see if you can slid the inner cable out and check it....
Well imagine that you have a cable within a sheath, and you twist it, twist it, twist it, twist it, twist it, twist it, twist it, twist it, twist it, twist it, twist it, twist it, in one direction and it finally snaps. The little cable fibers are twisted like little prickly springs all in one direction. So when you continue to twist it forward, the little springs slide over one another. BUT... when you go in the other direction, the little burs just happen to catch enough to spin the cable in that direction.checked the gear and looks almost new. only had the truck for about a weekif it the cable is broken why would it spin one way at the dash and not the other??
Well I guess with these gas prices, it'll either be your tank, or your wallet that'll be emptyI got ya. It looks as if someone replaced the gear and when that didnt work they quit. Guess I'll try and do the cable today. Then Ill tackle the gas gauge that stays on empty all the time. :mellow:
