rear window switch
swampthing
ok need a little help with a wiring issure for my tailgate window....everything works fine but when i bought the truck last summer the people cut the plug out of the dash and threw the switch into a box...so as it is right now i have a hot wire at the dash and i have wires running up from the tailgate and i have to plug the wires in together and ground off on my floor to put the window up and down...on the switch i have 4 prongs so my main question is would that have 2 hots and 2 grounds running to it or 3 hots and a ground....im confused as of right now did a quick search on here couldnt find anything and my haynes manual is a little messed up so i cant figure out the wiring diagram in there....a little help would be greatly appreciated
I also have tailgate window problems.
I ordered a new switch that I will pick up tomorrow.
Without a diagram and instructions of how to test it the switch, it really had me scratching my head.
I'll use a continuity tester and then...
I plan to draw a diagram and label the pins, then show which pins connect when the switch is in up, down and nuetral positions.
I am sure this will be helpful to many fellow forum members.
Hopefully when I am done, I will be able to scan the image and post it.
Wish me luck.
joe
I also have tailgate window problems.I ordered a new switch that I will pick up tomorrow.
Wish me luck.
joe
Here is the diagram
Here is the diagram
Thanks Fred,
I had this diagram when trying to figure out how to test the switch.
Frankly I couldn't figure it out.
It seemed that there were five wires each with a connector that made a variety of connections or NOT, depending upon which of three positions the switch was in.
Do you happen to have a diagram of the back of the actual switch?
joe
Thanks Fred,I had this diagram when trying to figure out how to test the switch.
joe
I don't think I do, but if you look at the diagram, when it is in the neutral position, you should have 4 pins connected to ground,(the two with black wires plus the Purple with light blue stripe and the Purple with light green stripe) and with the ignition key in "RUN" one pin connected to 12V. If you push switch to UP, 3 pins go to ground and two should have 12V on them, (light blue with black stripe and the purple with light green stripe). When you push it to "Down" the 12V switches to the Purple with light blue stripe. Hope that helps you sort it out.
OH... Nooo! Smack my self in the head!!!
For that dash switch to go live the ignition switch has to be in the RUN position?
I need a new manual... Ford Bronco's for Idiots.
OH... Nooo! Smack my self in the head!!!For that dash switch to go live the ignition switch has to be in the RUN position?
Actually Joe, it should also have 12V when in the Accessory position as well. Two fuses are used, one for the driver switch and one for the tail gate key switch.
swampthing
swampthing
i found that exact diagram thanks though fred i appreciate it..i still havent gotten around to it have been doing body work on it
figjeti
