After you do those things first, and they should be done before you go any further, make a list of everything you WANT to do with the Bronco.
#1 - 3.5" suspension lift
#2 - 33" tires & new rims
#3 - gears & lockers
#4 - roll cage
#5 - 1" body lift
etc., etc.
Then after you make a list of things you want to do with it, prioritize them and stick with that list. If you go bouncing around, you are going to throw money away when you shouldn't have. An example would be if you get a set of lockers and then 6 months later you want to lower your R&P gears. You will have to pay someone the money to set that axle up 2x if you do it that way, whereas if you save up the money and do it all at once, you only have to pay that price the one time. Come to the board and don't be afraid to ask questions. the only stupid question is the one not asked. And last but not least, if you have never worked on a vehicle like this, only take one side (be it the brakes or the hubs) apart at a time. That way you have something to look at if you get lost on the other side....Ask me why I know that one...
