CHANGING GEARS
79RAGTOP
Wisconsin
WONDERING IF ANY ONE HAS DONE GEAR CHANGE IN FRONT DIFF? OF 79BRONCO WITH DANA44 WENT FROM 3.55 TO 4.56, I HAVE THE GEARS AND AM JUST UNSURE OF THE "SETUP" AREA'S IE. BACKLASH PINION DEPTH BLABLABLA ALSO HAVE ANY OF YOU READ OR PURCHASED RANDY'S RING AND PINION DIFFERENTIAL BOOK??? ANY INPUT GREATLY APPRECIATED.
slippin
send me the gears and I Will install them on my D44 and take step by step pics for you. Its not to bad at all. just take pcitures and maker sure you put the same amount of shim in that you took out.
79RAGTOP
Wisconsin
OK .............. GIVE ME YOUR ADDRESS AND I'LL SEND THE 3.55'S WHEN I'M DONE
THANKS
figjeti
