Any Possible Way?
RammsteiNick
Connecticut
I have a dumb question, the answer is probably no, but I would like to see if this is possible.
Is there any possible way to get BOTH a lowerin kit and a lift kit in a bronco or Bronco II, and be able to switch between them using hydrolics? Yea, i know, stupid question, but if it spossible that would be sweet.
bigbad79
most likely no. if you use airbags you'll get lift but wont go any lower than stock. you'll also have lots of suspension travel if you want to lift and lower your truck so you'll prolly run into driveline problems. i say dont mix street trucks with trail trucks!
Ralphdb
Lakeland Florida
Could be a major PITA to get the camber set if you run the stock (TTB/TIB) front axle.
Man I seen that setup on chebbies with the hydraulic cylinders instead of shocks.. I guess a 4' long drive shaft could take the travel..up and down. don't try it with 4X4. As long ago this was he probably allready built One.
Your main problem would be with the TTB front axle, as previously mentioned it would be impossible to maintain the camber.
trailmule
South/Central PA
I had an 87 Bronco with dual airbags up front. Never again. I thought they sucked. Rode like ****. Not that Broncos are known for a smooth ride but still. The truck was orginally bought new in NC and we think was set up for beach running. Frame was rusted to **** as well.
And I agree, you have to decide on one thing - a lift or lowering. Mixing it doesn't really work. Sorry
stepchild
Lodi,Ca
Wouldn't Hydraulics be a lift kit and a lowering kit all in one? Why not just get lift air bags! Besides you can deflate them all the way and get a little lower.
bronco3
absolutely, thought of it myself. there are air ride [adjustable] kits for later models...saw on power block tv--when theres a will....
fred tyler
