88 Bronco II-Need Radio Wiring color Codes
RobAndCanWalker
I have an 88' Bronco II Eddie Buar ed. 2 WD. We are trying to change out the radio. It had the original Ford radio in it. The radio we have to put in it is newer and the connecters do not match up, nor do the wire colors. We tried to put the newer one in by following and online wire diagram, but the diagram was incorrect. We have the repair book for this truck, but it does not have the radio wiring in it, which we thought was strange. So, we need help with matching up the correct wire colors. Does anybody know what color wire goes to what in this truck? The newer one has all labeled wires, but the truck wires are not labeled. Thanks for any help. Also, has anybody ever put door speakers in this truck? If so, what size? Thanks!
Here is the diagram with color codes from an 83 FSB. Ford has been fairly consistent with color codes so they will probably match yours.
R
RobAndCanWalker
Thank you for the diagram. However, it is not the same.
Mine has two connecters that are original. They are as follows:
1st connecter: two greens, two purples, one red, one white, one purple, one yellow
2nd connecter: red w/white stripe, yellow w/black stripe, blue w/red stripe, brown, black, pink
Thanks
:) /emoticons/[email protected] 2x" width="20" height="20" />
kyleh01
