1973 Bronco lift
nebraskabronco73
Nebraska
I want to take and lift my bronco 3.5 inches with a james duff lift to get bigger tires and better look to it. I also want to take and cut the fenders and add the ufo flares are there any ideas for me i am just getting ready to purchase the stuff.
S_bolt19
Colorado
You will get more for your money if you buy your lift from Cage, Wild Horses or BC. Cage designed the lift that Duff uses a couple of years ago and has since modified it and made it better.
N
nebraskabronco73
Nebraska
I am confused i looked for Cage i know the site of wild horse but im not sure what the other names mean and i can't find a web site.
TX '73
Texas
You don't have much to worry about w/ a 5.5 inch suspension lift if you get a good, complete kit from one of the venders mentioned above, other than extending break lines, e brake cable, drive shafts. 5.5 inch is a pretty big change. If I were you, and was about 6 months ago, I would look closely at the difference between 3.5 in versus 5.5 in lift kits and 33 inch tires versus 35 inch tires. Look at the different combos and do the one you really want, the first time. Personally I did 3.5 in w/ 33 inch tires and am completely satisfied. However I'm just an off roader, not a rock crawler.
77bronco77
if i was going to spend the money on the 3.5 and 33s id just go all the way with a 5.5 and 35s. you will have to spend some extra money on drive shafts and brake lines and such as stated above. but it would only come out to be an extra few hundred bucks....just my $.02
im gettin ready to lift mine 5.5 and get some 35s and sell my 33s.
eholt80
