PLEASE help me... does anyone know whats wrong
xbigxblu3x
PENSACOLA florida
ok. so my 88 bronco II will not go in gear. i was driving down the road and i put it in 5th gear. i started going up a hill so i went to drop it into 4th and it wouldnt come out of 5th i pulled over and turned the truck off to see if it would come out then.. AND NO it was stuck. i had to take off in 5th gear.. I KNOW it ate up the clutch but i was wondering what is wrong besides that. now that it is parked in the yard it will not go IN gear its out i dont know how it came out but its out. and i can start the truck and i can put it in what it feels like gear but its wont go anywhere even when i let off the clutch it just sits there . even when i turn the truck off put it in gear and start it. it will not move. i dont know whats wrong and i dont know what to do. ppl tell me its the clutch and ppl tell me its the tranny and i just dont freaking know. i was wondering if anyone has a clue what i need to do without blowing 5/600 dollars at a shop. please help meee. thank you for reading this and thanks anyway if you dont know
X
xbigxblu3x
PENSACOLA florida
if you ask me i dont see the point in having an account on here because noone ever helps me and theres never anyone online. its kinda sad that you have a site this big and noone uses it. but ok w/e
yusuebronko2_86
San Antonio TX
to start off, the site would never get big if nobody ever uses it. it usually takes a couple of days for somebody who's had an experience similar to yours to respond, since the majority of users are north american and have normal working lives.
now then. as per your problem, i know exactly what's wrong, but the chances of fixing it with replacement parts is slim to none. the problem is in the latter section of the transmission, after the gears towards the center of the case. there's a series of meshing gears there that have a separating ring or clamp. this clamp, when under severe loads or wear, can get lodged between the two gears and cause the shifter to get stuck also. mine got stuck in first gear because i was playing too hard with low gear, and thus it "locked" in first. i managed to get the shifter out of first, but the tranny was still in gear. putting the shifter in another gear just jammed everything and the truck would not move.
i've had the same situation happen to me, and i tore the tranny completely apart to find the cause. in an auto parts store, i could not find the small little ring that goes between the gears (and gets eaten up and jammed between them). i opted for a "rebuilt" transmission, but the first was a lemon (autozone imported one from a shop). get ready for a weekender, and a new or rebuilt tranny. a good bet is to upgrade from an FM 146 to an M50D-R1 from a 4.0 vehicle.
that about does it for me, as i'm currently in college at the time (in class while typing). just remember to be patient and understanding on this site, and you'll get what you need to get the job done.
-yusuke
X
xbigxblu3x
PENSACOLA florida
-yusuke
dude seriously thank you im glad somebody replyed and its at the shop right now actually. im not sure how much its going to cost yet but they said they are gonna get it fixed i told them i have a budget of 350 dollars and to get it running again i have school. and i gotta start like NOW i was supposed to start last week and this sucks man but thanks alot atleast somebody knew i was here.
X
xbigxblu3x
PENSACOLA florida
ok well at the shop they havnt pulled the tranny out yet but they did pull the top off of it and the shifter was broken since it doesnt have berrings or anything and it has snaps or something .. they replaced it all cause it was broken. but we will see what happends to night on if it is fixed or not
viperfangs2
Northwest Florida
hey dude i live in navarre florida what shop did you take it to? be carefull p-cola has alot of crapy shops but there is a shop that will rebuild your tranny for like 200 to 400 dollars in pcola but you have to pull the tranny out your self which is good for learning. you will also have to figure out how to get it to the shop i will ask my buddy what the name of the shop is!!
i love north west florida white sand beaches and girls girls girls
4X4RedNeck
Manually tranny? Take it out yourself and look in it. Not as hard as you may think. Easy weekend job just to take it out, open it up, and look for yourself. Look for worn gears, etc., or loose shifting (or wiggling).
agzmdv
Related problem with my 89 B II, 2.9ltr 5spd. It was hard to shift in all gears, but with motor off would shift smooth. Long story short, internal ***** cylinder was the problem. While I was in there (weekend project of dropping tranny, shafts, xfer case, etc), changed clutch, pressure plate, and pilot bearing. Shifts smooth, runs great.
fred tyler
