junkyarddog
Hi guys, I have a heater problem. I know this has been discused at length however, I haven't solved my problem and have questions. I got a new heater core but the heat still will not blow hot. So, I took someone's advice and removed the blower motor and cleaned out all the crud inside the box that the motor bolts to in the engine compartment. WHen I took the motor out, I noticed a flapper door inside the box where the motor bolts. It appears to be actuated by a some kind of solonoid switch with a little plastic vaccuum line attached to it. What is this door for? Is it supposed to open when the heat is on? That solonoid is on the outside of the box right next to the fire wall. Right now, it doesn't open the door when the heat is turned on. The door looks like it opens into the cab into the compartment where the heater core is located. I guess this is why I am asking. It's on a 90 full size with 5.8 liter motor. I wish I had pics but I don't. Thanks for any advice. By the way, both of the coolant lines that go to the back of the heater core become hot when I run the heat so I know it isn't any kind of obstruction in the lines or core. Thanks again
