At the end of the day you'll be a LOT happier with an Add-a-leaf than with blocks. Blocks require longer U-bolts and the longer bolts and altered geometry make for an increase in the lever effect, the fact the the U-bolts are longer & the springs not sit further from the axletube means that when you engage drive or reverse you have a lot more force being applied to the mounting points and this tends to show up over time as backed off U-bolt nuts and skewed lift blocks. Granted if a rear lift block slips out you probably won't lose all control of the truck like you would if it were a *front* block (which is why nobody smart uses front blocks) but it's STILL going to be enough to ruin your day.thanks for the welcome. ya i have aligment troubles, i have to get the kit that lowers my radius and I beams so i can get it aligned. Ya i was wondering if i was going to have to put a 1 inch block kit in the rear to level it out but ill wait a month or so
Leveling kits always seem to be a hit-or-miss kinda thing because everyone's suspension is really a one-off after 15yrs or so and from what you're describing it sounds like you're going to ultimately wind up with a 1" lift in order to get your rig to sit level.
The Add-a-leaf really isn't much more work than a set of blocks, well, ok maybe just a little bit more work <grin> but in the end you'll have a much better look and everything will be level which is really your goal. On top of all that even with doing the rear leafs you'll still have less $$$ into it than if you'd replaced all of the suspension with stock pieces.
Everyone's truck wears in differently and after a decade or two they all sit a little bit different. JSM is dead on to suggest waiting a few weeks to see how it settles in. Put a few miles on it and see how it sits in a month or two before making and big decisions. A LOT of times they settle in & sink down a bit once the initial stiffness of the springs goes away.
