Tranny/clutch noises, I think
Krafty
Ontario Canada
Hey guys Here's whats going on,I have an 81 Bronco 300 I6 with a heavy duty 4spd tranny. I had two problems that I fixed and now I have this third problem that might be related to the other two. First my truck overheated three times and last time the rad blew so there was no coolant whatsoever. I replaced the rad and now I need to replace the gaskets on my water pump but thats a different story. Second problem was a terrible shake in the truck at between 1900 and 2200 rpm in 2nd and 3rd, but in 4th when I went over 95kms or 55ish mph it was unbearable. I found a screwed U-joint the had melted itself the collar and the yoke that I replaced with some effort.
Now Problem is a noise or clanking that sounds like it's coming from the tranny or clutch. its not coming from the rear end because its not there when coasting and its not the motor because you can clutch and rev it and its not there either. It is most noticable when I first start accelerating, once the motor starts moving the truck as I engage the clutch it ticks like a metronome its always there except for when coasting or the clutch is disengaed ( same thing I know) , it goes faster as you accelerate.
I checked for anything loose on the outside of the transmission and everything is solid and tight so it would have to be something to do with the clutch, any Ideas?
D-Man
NorthEast, the land of salt & rusty trucks
Hey guys Here's whats going on,I have an 81 Bronco 300 I6 with a heavy duty 4spd tranny. I had two problems that I fixed and now I have this third problem that might be related to the other two. First my truck overheated three times and last time the rad blew so there was no coolant whatsoever. I replaced the rad and now I need to replace the gaskets on my water pump but thats a different story. Second problem was a terrible shake in the truck at between 1900 and 2200 rpm in 2nd and 3rd, but in 4th when I went over 95kms or 55ish mph it was unbearable. I found a screwed U-joint the had melted itself the collar and the yoke that I replaced with some effort. Now Problem is a noise or clanking that sounds like it's coming from the tranny or clutch. its not coming from the rear end because its not there when coasting and its not the motor because you can clutch and rev it and its not there either. It is most noticable when I first start accelerating, once the motor starts moving the truck as I engage the clutch it ticks like a metronome its always there except for when coasting or the clutch is disengaed ( same thing I know) , it goes faster as you accelerate.
Just a wild ass guess but is there ANY chance it's an exhaust leak right at the mainfold ? I've had them before and they can be surprisingly quiet when there's no load on the engine. If you have a turbo muffler of something like that it can mask the soft tick they make but when it's in gear and under a load the sound really picks up.
Krafty
Krafty
Ontario Canada
I do have a couple of exhaust leaks but Ive had them for a long time, I even welded them up, so I know its not my exhaust, and the ticks speed up with the speed of the truck and not with the rpms of the engine, I can also feel the ticks, in the floor and the pedal, it's no small tick its like tapping steel with a hammer, and I just have a cheery bomb glasspack with a turndown so its loud anyways, Ive had this truck for the last 6 years and its never made this noise before
Krafty
Krafty
Ontario Canada
it tuned out that another piece of the drive shaft had failed, I replaced the whole thing with a two u joint unit from the front end
