HELP PLEASE
bluefordcat
SOUTH DAKOTA
I have a 1994 w / 5.8 what can I do for pumping up the power? ON a computer controlled Engine????
I not able to find a power programer or chip for this year & Engine? any help here?
K&N Filter??
Airaid or Street performance throttle spacers help?
How about the tornado???
remove the catalatic convertor? will that help or hinder?
runnig duels with a CAT? or with out the CAT?
how do you fool the O2 sensor?
Air pump - pumping air into exhaust is it nessarry or? engine modication will that ***** up the computer?
It is a fantast Bronco I'm looking to boost it up?
See I need lots of good sound advice here!!!!!!!!!!
bidibronco
Norfolk Va
I also have a 94 and I have 24lb/h injectors, a BBK fuel regulator, edelbrock performer intake, twin 56mm throttle body, 1.7 roller rockers an aftermarket cam (204 intake/214 exhuast duration @ .050) true dual exhast with no cats. Oh, I have no computer mod's either. From fullsizebronco.com my truck is set up with enough modifications that it shouldn't run. Well, she runs like ****, just gets in the neighborhood of 9mpg. That's what I did for more power, just don't go to big with a cam or anything and you'll be alright...
89Bronco58
Jersey
headers, full exhaust, k & n intake system would help greatly, remove the stock mechanical fan and replace it with an electric one. Do that and you will see quite a difference, i know i did :D /emoticons/[email protected] 2x" width="20" height="20" />
bluefordcat
SOUTH DAKOTA
If I remove the Catalatic convertor what do i do with the O2 sensor & false readings to the Computor? the air pump that is pumping air into the exhaust manifolds I Believe. can I remove it trash it or will I have a over heating issue with the valves? Headers Shorties or long tube if I can find them shorties seem to be the most advailable?? the ebay Links-
Progressive tuner or the performance mod chip or super chip which one it the way to go? looking to boost power but improve mileage if I can..
bluefordcat
SOUTH DAKOTA
loving my Bronco!!!!
bluefordcat
SOUTH DAKOTA
