Truck runs like crap
firelt90bronco
Ask me about my job
northeast
I posted before about how my truck would run at high rpms and slow speeds up hill, smell like its running rich and have no power. So far i have replaced the engine coolant temperature sensor, ignition control module, coil, catalytic converter, eec and fuel pump relays. I cleaned the egr, checked the spark plugs, checked the fuel pressure and the transmission. What else is there?
snowman74
Oklahoma
Jim,
Have you checked to make sure you're getting fire and fuel to each cylinder? When mine was running like ***** it was those damn injector wires. Check your spark plugs and wires.
Snowman74 :)>-
F
firelt90bronco
Ask me about my job
northeast
How would you check the injectors and injector wires? The truck is very sluggish and has a hard time getting up hilss.
F
firelt90bronco
Ask me about my job
northeast
I noticed today that one of my spark plugs had a crack in the porcelin and one of the wire boots broke. I think I'll replace the plugs and wires and see how it is from there.
F
firelt90bronco
Ask me about my job
northeast
It was alittle dirty, I'll replace it when I get the chance. Like the verse listed on your signature.
89Bronco58
Jersey
id just do the basics first, mainly a tune up and fuel filter. if thats not it id start checking into the sensors on the throttle body, is the check engine light on? also check the whole ignition system
snowman74
Oklahoma
I fixed it today, the timing was way off.
Have you been playing with your distributor again Jim? Ha ha. I still say you ought to replace those sparklers and wires. A cracked plug is as good as useless.
Snowman
Gryph
