1991 Bronco parts interchangability for 1979 Bronco.
mgawat
Maine
I'm doing a project both on a 1979 Bronco and a 1994 F250 and I have access to a 1991 Bronco. I was woindering if any of the body parts and frame parts from the 1991 Bronco can be utilized on the 1979 Bronco (Top, tailgate, body mounts, frame crossmembers, etc)>< Any help would be appreciated
79highrider
Frenchtown NJ
I know the tailgate can be used from the 91 to the 79 if you change the pins and window, the tops are different, as for cross members i don't know but I do know the frames are shaped different, 79 bronco frame is 33 or 34 inches wide all the way, the 91 frame is 33 or 34 inches and spreads out in the front to 40 inches so I know front bumpers don't work, body mounts should be close to the same since they are both full size tubs.
figjeti
