problem staying running
firstford
I have a 90 fullsize bronco 5.8 ,351w when i cranck it it run at a high idle then it goes down. When i put it in gear R or D it cuts off even if i im giving it gas. HELP IM DOWN TO MY LAST STRING OF HAIR.
bidibronco
Norfolk Va
If memory is correct a 90 MPFI and it may be your throttle posion sensor or you may be out of time. When it's warmed up what does it idle at?
F
firstford
The T.P.S in new change it anyway it did the same just put a timing chain on set 10degrees BTC
bigtrux
Murrieta,CA
Are you sure you aligned everything back up properly when u put on the new timing chain. Also when you dropped the dizzy back in are you sure you had #1 cylinder on compression stroke not exhaust . Another thing maybe are your wires in correct firing order hey anything can happen just askin.... well good luck ....
F
firstford
Thanks guys but it was the last thing i would've thought of it was out of TRANSMISSION FLUID.Im a greenhorn on ford & 4x4 i guess you learn something new everday and again thanks
