300 6 to 390 bigblock
Krafty
Ontario Canada
Hey guys, I got some power issuses in my Bronco being as the 117 Hp 300ci motor isn't pushing my 81 Bronco with 33s and 4inches of lift as well as I like, I got a 300hp 390 big block sitting on the floor, and I need some parts advice. The 300 is bolted to a heavy duty 4spd and transfer case, the 390 came out of a two wheel drive with a front drop pan, and is an automatic. Should I try to find a big block 5spd for the highway, that will bolt up to my transfercase or go to an automatic? I got a steering wheel and assembly for an automatic, What will I need to find for that kind of swap, 300 manual for a 390 bigblock auto?
SoFlaSwamper
first, the 390 is not a big block...its a small block ford with a big block bellhousing. ;) /emoticons/[email protected] 2x" width="20" height="20" /> its a great motor though. If you're going to do this swap you either have to get a four-wheel drive tranny (auto or stick) or a divoriced transfer case with custom shafts made. The tailshaft on the tranny of a 2wd won't have an input shaft for a t-case.
its a fairly easy swap, just time consuming and the ins and outs could drive you to drink!
You are the first one I have heard refer to the 390 as a small block. It belongs to the FE engine family and is considered a big block as far as I have ever known
BLADE262US
Michigan
Yeah thats a first for me too those motors are very big and very special nothing big or small blockish about them as far as were used to today , completely on there own the FE engine family includes the 332 , 352 , 360 , 361 , 390 , 391 , 406 , 410 , 427 , 428 . They were produced from 1958 to 1971 and with the right combination of parts these motors could produce over 600 HP . Parts are kinda expensive due to limited demand . You will not find any newer overdrive tranny or manual tranny for that matter that will bolt to the FE motors they have a unique bellhousing pattern :D /emoticons/[email protected] 2x" width="20" height="20" />
Read this kinda interesting :D /emoticons/[email protected] 2x" width="20" height="20" />http://en.wikipedia.org/wiki/Ford_FE_engine#360
stusainte
01085 Ma.
I never hear that eather My Brother has a 390 W/ tripower and when he he had it rebuilt everything was orderd for a 390 big block motor ( Wish i could steal that motor from him LOL)
Johnny Reb
This is to Frafty-the 390 is a big block motor. You can not take a small block bellhouseing and mount it to a big block. To put a big block 390 ford engine down into your bronco. You will need a set of torches to burn the holes bigger in the steel motor mount plates that are connected to you frame. You will have to tkae the measurements first. Then you will need a 460'400 or the 300 bellhouseing to bolt up to your 390. It is a shoe in. You will also need to fabricate your clutch bar ,from the frame to the engine. I also went and put a 4 row radiator in my bronco. I done this work on a 78 bronco.. And you are better off going to a poit distributor. In my opinion----------it has more power . Good luck. It is no big deal. Look it all over and you can see ,you can do it. I hope this clears thing up for you.
mustangtoby
Southwest Colorado
There are five major engine families of Fords. The small block (260,289,302,351W), The 335 series (351M,351C, 400), The FE series (332,352,360,361,290,391,406,410,427,428), and the 385 series (429,460). The small block has its own bolt pattern, the FE has its own, and the 335 and 385 have a common bolt pattern. The only variation is the 351C, which has the small block pattern. You can use the 390 engine, you will have to get creative with the motor mounts, exhaust, radiator plumbing, wireing, etc. Nothing to major. You will need the rear sump oil pan, or the front end will self clearance the first good bump you hit. You will need the bellhousing from an FE, and the best transmission t-case combo would be from a 78-79 truck with the married unit. The 70's model 1/2 tons all had married trans, but the 3/4 tons had divorced until 77. 76 was the last year for the FE in trucks, and 72 was the last year in cars. IMO the FE was one of the best engines Ford ever made. They made great torque, but the heads really limited them in the horsepower dept. Edelbrock makes a set of aluminun heads that can really make some power. They also make an aluminum intake. As far as I know, these are the only aftermarket heads and intake for the FE. I have done this swap into an 83 myself, and it worked great. If your not to mechanically inclined, then I would suggest going with an engine that Ford put into that body, because you can find all the parts to make it a bolt in swap. These bodies 80-86 came with the 351M, 400, or the 460. These were the only v-8's Ford put in these trucks. IMO the 351M-400 make good boat anchors, but very little aftermarket support, and very hard to get much performance out of. The 460 is the best bet. Hope this helps.
Krafty
Krafty
Ontario Canada
Hey guys thanks for the imput but I decided to just swap it out for a less tired 300, turns out the old one had next to no compression. Now ive set my sights on a 302 to 429 swap in my 79 T-bird, it'll be one **** car
