changing over to a 4 barrel and other Q's
Cmprice
well i have a 400m with 67k miles on it original and i saw the kit from summit and would i need to do anything else or is it bolt on? and what are the advantages? more hp, torque, possibly better gas mileage?
also i saw the tornado thing that goes inside the filter .....any expieriences? worth it? i may ask some other questions here too so i dont make so many threads....
oh ya how do u get the **** off of the light control so i can get the dash off? that would be most helpfull right now
If the kit didn't include a new 4 BBL intake, you will need one.
Those things are just gadgets and not worth the money. The idea is to get the fuel to vaporize better. There are better things you can do to improve mileage. Check this site http://www.lubedev.com/smartgas/
You can release that **** by using a L shaped pick. The **** is held on by a pressure clip that can be released by pressing against the edge of the clip with the pick. Just put the pick behind it and tilt the tip slightly back toward you while pulling on the pick.
If you have no luck getting the **** off, there is another way. You need to get your habd in behind the dash to the body of the lightswitch, shouldn't be hard to get to. Feel around for a button on the side of the metal body, push the button and pull the **** out like you want the lights on, the **** and the rod its attached to will come out.
figjeti
