Has anyone changed out the heater core in their early Bronco? I believe mine has a minor leak as the bottom of the heater core has some moisture present. Do you have to pull the entire heater assembly out of the vehicle in order to swap out a new core? Also the repair manual says to drain the coolant out before pulling the heater. Can you instead clamp off the heater hoses to avoid draining the system? Or does this cause some sort of "air bubble" in the system?
Thanks for any input.
Bernie
Bernie
