Light issues
pj31704
Texas
I'm not great with electrical work but I am about to take my '73 in for it's inspection and the back left tail light and side marker are not working. I know the light works because the blinker works. Its only the driver side tail light and side marker. I'm guessing something with the wiring but also wondering if it could be a fuse. Has anyone had an issue like this before? Appreciate any thoughts on the matter. I have looked for a fuse box under dash but can't find one.
Hi PJ..,
What you're describing sounds like the one of TWO filaments broken or burned in your taillight bulb.
Remove it & insp. If both filaments are in place, clean the socket & bulb base.
Same for the side marker. replace bulbs if bad & clean sockets. At a later date, do this (clean) with all the rigs bulb sockets.
Lime-a-way & a Q-tip are great for this cleaning. Rinse with a damp cloth.
Lastly., there's bulb-socket grease avail. that makes good contact & protects the socket fr. continued corrosion. >:D< <'>
BTW your fuse panel should be in the glovebox.
P.S. if there is a wire cut/broken.., you can find it with a volt meter or a "light-up" circuit tester.
pj31704
pj31704
Texas
I have checked the bulb, it works and both filaments are intact. I also took the light socket out and tested it directly against battery and it works fine. I am guessing somewhere in the wiring there is a problem. I have traced wiring all the way to fuse box and it all seems to be ok. Almost out of ideas but really would like to fix this problem myself. Any other possibilities? Fuse seems ok and all other lights are working. Only back left tail light is out.
What about the side marker...is it now working..?
The schematic shows a wire directly from the light switch to the left taillight, thru several male/female plugs.
The RIGHT taillight wire taps into the 2nd plug back from the left taillight. This wire also energizes the license plate bulb.
If right side lighting works.., your prob. has to be between the left bulb & the 2nd. plug.
A quick fix would be to place a jumper wire from right tail, or license plate bulb wire.., to the left taillight.
I have checked the bulb, it works and both filaments are intact. I also took the light socket out and tested it directly against battery and it works fine. Only back left tail light is out.
By checked against the battery do you mean you used a voltmeter and checked from the contact in the socket and the frame and got 12V? If so, then I would suggest that the grounding for the socket is bad, or that the hot lead is broken and when the socket is in place the wire is in such a position that it the brake opens up and you no longer get 12V to the contact.
rustyoldbronco
Afton,Wyoming
I kept having random issues with random lighting locations in my '73.it was diving me nuts.One day I happen to see my grounding strap,and it was severely corroded.I put in a new grounding strap,and most of my lighting issues disapeared.donn
spencer's76
So where is the grounding strap?
fred tyler
