fuel economy on an 86 with 302
jeepkid
so bacially my fuel economy isnt to good ( i knew this was going to happen anyway) and i was wondering if theres anything i can do to inprove it, besides changing my driving habits which i am also working on. i have a 302 thats brand new, re built tranny, and i believe 36 inch bfg all terrains, i working on cutting off my ranch hands as well since their heavy. are there any parts or kits or something that will help me? i heard dropping my front driveshaft will help BUT that means losing 4x4
I doubt that you will get any improvement by dropping the front drive shaft. If your hubs are not locked the shaft is disconnected from the wheels and doesn't put any drag on the system. If you don't normally use your back seat, remove it and only put it in when needed, and any other way you can reduce weight. Driving habits are a key if you are prone to racing the guy next to you to the next light or trying for a record 0-60 every time you leave the line :D /emoticons/[email protected] 2x" width="20" height="20" /> . When ever possible use cruise control, it is less spastic than most drivers.
J
jeepkid
i dont have cruise control, it broke before i have the truck.. i know cruise would help and keep me from speeding as much.. and i need to correct myself, the tires are 32's and no they havent been regeared YET. a reputable 4x4 shop quoted me about 1600 to re geard from and back with 4:10s i think
You should include your truck statistics in your signature, it helps in answering questions.
As far as the cruise control goes, check the basics: Fuse, connections, vacuum lines (including the vacuum dump switch located on the brake peddle, it may just need adjusting because it somehow got moved too close to the brake peddle arm), connection to the throttle.
eholt80
