Removing Body Lift
newman0911
Fayetteville, NC
I just bought a 74 Bronco. Has a 6" suspension lift with a 3" body lift. I am going to remove the body lift, but am new to this. Is there anything to worry about or is it just removing the spacers and installing new bushings? It seems everyone says it is pretty easy, just do not want to get started to find out I missed something. Thanks.
No experience here with body lifts....but, what trannie do you have....?..it may interfere if not stock.
Do fill-in you info pages so as to get accurate info..!!! :unsure:
N
newman0911
Fayetteville, NC
From what I can tell (from my limited experience), eveything other than the suspension is stock. Auto C4 tranny. Just do not know if I can remove lift and all is good or will I run into problems with any lines or linkage. Thanks again.
bigbluebronc
ca
Fan shroud, carb linkage, incl. kick down..., steer. shaft alignment.
Poss. shift linkage adjustment.
Wow thats a tall rig 9 in lift what are you running 42s or is it a mud truck, or a 20 chrome shock show rig, these days everybody in California is running big tires on low rigs with big cut outs
any way git rid of that body lift here are my helps
Rear too back
Fuel tank they make 2 in body lift fuel tanks check clearance
bumpers may have been lifted tailgait might not clear after body lift removed
mufflers may be lifted with the extra space
aftermarket seat bolts may hit frame or other brackets
I took out a 2 inch let me think
as you take it out the tube will flex and doors might not fit as same
steering shaft should colapes if it has a slipshaft if not cut and modify
throttle adjustment a must
air filter too hood might hit
radiator/ fan shroud ,radiator most likely had drop brackets, replace too stock or cut bend weld too fit
send pics for more help, I have removed my 2 in body lift as well
BBB
fred tyler
