Hey All. I am excited and just bought a 1971 Ford Bronco. It has been sitting in California for 4 years and neighbor who I bought it from her in Indiana said it was running before it was truck lifted her to Indiana.
At first I replaced the starter solenoid and got the engine to crank. Also replaced the battery and both terminals. However, it was not getting spark to the coil. I took the lead off of the coil and cranked the engine, no spark. Tried again off of the distributor cap, again, no spark. I then bought a new coil. Again, same scenario. I then went and bought a new ballast resistor and again no spark to coil.
I used a light tester. Got power to the side of the resistor going to the coil but no power/light at the positive side of the coil.
I am at a lost for words. It is an old ignition switch. Only an ON side to the left, and turn on side to the right. When turning right, stays in the position and cranks the engine. There is no spring mechanism that I am used to with new cars. Only can test the power to resister when I am cranking the engine. Will not get any other way.
Any help would be greatly appreciated. Thanks so much.
Joel
Joel
