I put those headers on mine, ran back to individual pipes, two turbo mufflers and out, no issues at all. Plenty of back pressure for the truck.i have true dual exaust on my truck with 2 glasspacks on it no cats and im buying headman long tube headers do i need to worrie about not haveing enough back pressure? o and the pipes are 2 1/4.
As long as you don't need your emissions system to work, you don't need any back pressure. Think about an engine used for drag racing, do you think they have any? Back pressure is a robber of power. That being said, I refer you to your local emissions control station /emoticons/[email protected] 2x" width="20" height="20" /> . In most states doing anything with the stock exhaust technically makes it an off road only vehicle. So, "Don't worry Be happy / ".i have true dual exaust on my truck with 2 glasspacks on it no cats and im buying headman long tube headers do i need to worrie about not haveing enough back pressure? o and the pipes are 2 1/4.
Interesting...but I would think if you unbolted the exhaust manifolds, alot of other things under the hood would burn or melt before the valves.x said:Federal regulations still apply: modifying, deleting, or defeating emissions controls is illegal in the US, and generally bad for performance anyway. The engine will run better the way it was designed & built to.
And the correct amount of backpressure is necessary on all modern engines. Try unbolting the exhaust manifolds & see how long the valves last. This is from an engine with too large of ex.man. runners & a big fart cannon muffler.
as long as you have the right amount of restriction somewhere , aka engineered headers, then you can go 3" no problem. the biggest header tube size I would go is 1 1/4 or 1 3/8 and no bigger than that. but usually thats what they are unless you get custom headers. after that you can run anywhere from 2" to 3" pipes comfortably. anything more and your motor will feel gutless, and anything less it will be obviously restricted.
I have stock manifolds on my 429 ( which will be headers by april ) and true dual 2 3/4 " pipes to and from magnaflow mufflers, runs like a champ at 400 hp for the last 2 years.
also just for thought.. in the formula 1 cars that push crazy power and speed. they're headers have to meet this requirement . for both exhaust headers, each one has to at some point restrict to the size of a nickel before they can reach the rest of the pipe work.
ok well y yall are arguin all throw sum fuel on the fire what about paint like the balck painted or the thermal or the ciramic is the money worth it or do i just replace the painted ones every few years?
Mine are ceramic, been on for over 3 years and look brand new. They also cut down on heat under the hood...made a big difference in mine.While I haven't used the ceramic coated products, friends who have hotrods and show cars swear buy them.But they also recommend painting the inside of the tubes with VHT. They say it won't stop rust completely, but will slow it down and give longer life to your headers.
I'm curious what some other guys have experianced.
I have the Headman, long tube, thermal ceramic coated ones and after 3 years they look brand newwell what about the headman thermal coated ones there 285 vs the 437 for the cirmaic
Are you stating that one with performance is one without experience? That's pretty assumptive."x said:You're missing the point. Without the experience to use that performance, you've only created a rolling coffin. That's the whole meaning of that line. http://broncozone.com/forums/public/style_emoticons/#EMO_DIR#/wink.gif
I thought you told be earlier you were relaxed....doesn't sound like it.x said:No, I didn't say anything remotely similar to that. Stop trying to stir $#!+ up.
